Martin, never checked out the unit from Allen that does sound like a great choice though.martin manning wrote:Allen's TP2X is perfect. Note his rating is 260V @10mA, 260*1.41 = 368.ToneMerc wrote:I've looked at that one before, I thought was just not enough using a FW bridge and far too much for a doubler.
I spec'd' up a small open frame PT from Heyboer the other week and I should see them soon. If anyone is interested I can check on my price for maybe 6 of them.
1.5625" tall, 140V @ 30mA, 6.3V @ 600mA. It's heavy enough to handle a 12AT7 and 12AX7 if one wanted to do a two tube version.
TM
I have one here: I measure 286VAC unloaded from 122VAC primary.
Tube Depot's "The Button" trafo
Re: Tube Depot's "The Button" trafo
Yep, it's 47uf/25V. Now the trick is to pinch this, the PT and the Triad choke into a small box.Structo wrote:Nice!
Is that your cathode bypass cap there? The fat grey cap?
Remember that it should be 47uF. Or at least 25uf.
TM
If you want to get rid of your Fender Stand Alone Reverb Transfomer you could do it like this:
www.RedPlateAmps.com
Henry, about 6 months someone relatively nearby posted one your units on eBay. He listed it twice and the second time he even dropped the price and nobody bidded on it. At the time I figured I didn't need a lator that small, i'm kicking myself now.
Mike
Mike
Hellhammer
/Stewart
