Hi guys, this is the story so far... and it's not all good
Finished the build on Wednesday, did all my checks, everything seemed fine so I hooked up the bulb limiter and fired her up. Bulb went bright then dimmed, looking good so far.
Checked the B+ at the recto and it was 207v, seemed a bit high, also heaters at 3.5v each. I followed the 100R "virtual" CT and didn't use the heater CT.
Hooked it up to the mains, and a loud hum from the PT on standby, flipped the ON and the led indicator was on and quite bright, B+ still quite high.
Put in some bench tubes I had lying around and connected the speaker, heaters on OK but with 7v quite bright, flipped the power, the hum was there still and the el84 started to redplate. I had an HV fuse on the HV CT (0.5A) and this popped. Mains fuse was 2A slo which I guess was quite high.
If I touched the tip of the input cord, there was sound coming through, but before I could check any voltages, the el84 redplated again and the mains fuse popped. The PT was now really hot and smelling bad.
I popped another mains fuse in and it blew straight away.
The PT was nearly smoking so I guess it now had a dead short.
Got in touch with Azatplayer who is corresponding with me on this build and he mentioned the 2 diode fullwave recto as per AX84, which I
didn't have.
I mostly followed the Colossal schemo for the PS and that had a 4 diode bridge recto which I used. Apparently this is wrong with a Hammond 269/369 CT PT.
Anyway the PT was toast, so I got in touch with Phil at Bluebell Audio to order another. He confirmed I needed just the 2 diode full wave. And a place on Rectifier 101
Thinking this was going to be an expensive lesson, I ordered it but there are none in the UK so it is coming from Canada next week. The incredible quality of this man Phil is that he is letting me have this at cost to help me out. My mistake, but he doesn't want to profit from it.
The problem for me is I get a bit confused. I have been trying to build a hybrid from 3 schematics, the EF86 with the 101 HRM preamp and the AX84 power amp. I hope I have learned a lesson here and that no other parts are damaged - fingers crossed.
During this down time, I am going to replace the diodes with 2 x UF4007 and recheck all of my wiring and connections. Mains fuse is now 1A.
Heater CT will be tied to pin 3 cathode EL84.
To cheer myself up, I bought a new temp controlled solder station and ditched my cruddy old iron, so I hope some of the "bumps" in my build can now be a thing of the past.
Many lessons to be learned on this build, but I am not too down at the moment, it's warm and sunny here in England, which is unusual in April
All the best
Rog
