Could you please repeat the experiment and capture it on video for us?groovtubin wrote:dropped a pc of solder INTO the power tube socket area, ( ya know that darned soldering gun) didn`t see it, powered up, and WATCHED the HEATER resistors go up in FLAMES................it was actually kinda fun to watch! lolol!!
jim@Omega
Smoked My Amp
Re: short
groovtubin
Re: short
certified checks only pls!!Zippy wrote:Could you please repeat the experiment and capture it on video for us?groovtubin wrote:dropped a pc of solder INTO the power tube socket area, ( ya know that darned soldering gun) didn`t see it, powered up, and WATCHED the HEATER resistors go up in FLAMES................it was actually kinda fun to watch! lolol!!
jim@Omega
jim
Re: Smoked My Amp
That screw looks like it was gaulded in threads and to get it out was then drilled out.
In fact, I did it myself on a build when my cabinet holes didn't line up properly, and when I tried to turn out the screw it locked up in the aluminum threads of the chassis. I had to cut the screw and drill it out and re tap the hole. Alot of grief.
- David Root
Re: Smoked My Amp
Cautionary tale indeed! I've had one of those with a piece of solder, which is not so bad because it immediately melts & disappears.
I guess we all have experienced this, but, as James Bond might put it, "shaken not stirred" is the way to go!
Re: Smoked My Amp
Yeah, I love that macro setting on the camera!
Hmmm the only thing that was drilled and tapped was a chassis mount screw that I got cross threaded into the nut.
I suppose a piece of that screw could have fallen out when I drilled it.
Geez, that was months ago.
I wonder how it has been floating around the chassis then end up there.
It's not like I'm throwing this amp around.
Weird, but another lesson learned.
Re: Smoked My Amp
Hi,wath a mess.
But ist this the peace of printing Knob mostly on Jeans jackets. You knoe you push man and female together. Looks like the half which was in the female. I had once something like that.
Hans-Jörg
Hans-Jörg
