Vishay/ BC PR01?
FUCHSAUDIO
Re: Vishay/ BC PR01?
Post by FUCHSAUDIO »
FYL wrote:
Andy Fuchs and John Suhr got screwed by these tiny resistors, they open up in plate load duty.
Andy also posted a few years ago on TGP about his problems with Koa-Speer 2W carbon films failing with only a 400 mW load, so he must really be unlucky when it comes to resistors...
I use the Panasonic or Mouser Metalfilms now. Metal Oxide for power supply voltage dividers.
I liked the sound of the KOA and these too (scottL suggested them), but they did have a breakdown problem in plate load locations. Not overstressed wattage wise, but apparently voltage wise they didn't like high voltages.
When you consider cold start is virtually NO voltage across the part, and at current they have 100 to 150 V or so volts on them, it doesn't seem they should have died. I did see arcing to ground planes with some parts, which we fixed by raising the part or jacketing in heat shrink...
Nice to know I wasn't the only guy who got burned..
FYL
Post by FYL »
I'm switching to russian made components.
Some are outstanding, most come cheap thanks to military surplus.
Well, this is the least of my worries. I'm taking a big leap during the weekend, upgrading from my old trusty Windows 2000 to W7.
I still have got a couple of boxes running W2K, others - including the laptop I'm using - run well tuned versions of XP. No Vista, no W7 anywhere. Oh and a lone XP/W98 measuring station using ISA cards. Perfect for the job. Why should I upgrade?
FYL
Post by FYL »
I'm not familiar with Mouser Rs. Are they from Xicon?
Board design is an art. And a science.
:shock:
FUCHSAUDIO
Board design is indeed an art and a science.....I hand layout the boards, no auto layout or routing for that reason.
The arcing had occurred on prototypes without solder masking. On production this issue does not exist.
I wanted to add that these PR01 resistors are made by Vishay/ BC Components.
I would use these in a pedal but not on a tube amp.
FYL
Post by FYL »
I route manually all important tracks, then use Eagle's autorouter with a very strict set of rules, then fine-tune manually the final routing. Time consuming but very well worth it.
Creepage distances are a problem when you mix HV and PCBs. Add residue, dirt, smoke, debris, Jack Daniels and beer in the equation and that can become a BIG PROBLEM.
VacuumVoodoo
Post by VacuumVoodoo »
FYL wrote: Creepage distances are a problem when you mix HV and PCBs. Add residue, dirt, smoke, debris, Jack Daniels and beer in the equation and that can become a BIG PROBLEM.
Don't guess, get it right early in the design:
http://www.ce-mag.com/ce-mag.com/archiv ... afety.html
Aleksander Niemand
affiliation:TUBEWONDER AMPS
Zagray!-review
FYL
Post by FYL »
+1. Alas many commercial products aren't properly designed.
CHIP
Post by CHIP »
Anyone have a source for 1W metal films, besides the B C comp./vishay PRO1? I've been searching all over the place, with no luck
Chip they are kind of hit and miss at Mouser.
They don't carry all values in a certain type of resistor so you have to hunt around for them.
Be sure to read the data sheet before committing.
If it says the outside diameter is 2.5mm or so, that is a tiny resistor.
I like the standard one watt size for tube amp building because the leads are thicker and they are just easier to handle.
But these 1/2 watt KOA Speer resistors are pretty nice.
For instance these 1/2 watt KOA Speer resistors are .217" in diameter.
http://www.mouser.com/Search/ProductDet ... T521R1001F
But, they don't carry every value in the Speer's so you have to look at other suppliers.
Here is the list of Speer 1 watt resistors. Like I said the 1/2 watt are also a decent size.
1 watt
http://www.mouser.com/KOA-Speer/Passive ... sistance|1
1/2 watt, These are 700v resistors!
http://www.mouser.com/KOA-Speer/Passive ... d6Z1z0vl89
CHIP
Post by CHIP »
Thanks Tom, I saw those KOA 1 Watters, but they don't carry the values I need. (2.2 k,3.3k,220k,1m). Might have to go with 1/2 watters.
Yeah, I don't understand how they decide what values to carry.
Most probably tube amp builders aren't high on their list.
Don't forget Digikey and Newark as sources as well.
For example, Digikey carries the locking PEC pots I like to use for bias for $8.37 each.
They also carry some resistors that Mouser does not.
This is a PR03 Vishay/ BC 3 watt resistor. The outside diameter is .205" so just shy of 1/4 inch. They are 5% tolerance but the ones I measured are right on the money.
[img:200:200]http://media.digikey.com/photos/Vishay% ... FX_sml.jpg[/img]
David Root
Resistors
Post by David Root »
I agree that Mouser etc. are aggravating because you can't get all the values you need for Dumble type circuits (510R, 910R, 9K1, 91K and 110K spring to mind).
In 1/2 and 1W metal films I've standardized on PRP and Dale RN65s. Carbon Film, I use Takman CFs, carbon comp A-B NOS or Ohmite current production. The Ohmites and Dales I get from Mouser, the PRP and Takman from Parts Connexion (much cheaper than Angela for the Takmans). A-Bs wherever I can!
Takmans are a bit pricey ($0.75) but they are spot on usually value-wise, like metal films. Takman also does a metal film, but I haven't tried those.
2W I have been using Kiwame from Parts Connexion, not super audio grade but I don't have to have that.
markr14850
Post by markr14850 »
It's rumored that the Kiwame's are the same as a particular Koa Spear. Google can find you many hits on this topic.
David Root
So they are. FYL unmasked them 3 years ago apparently. KOA SPR-2. I didn't buy a bunch of them from Parts Connexion, will use Mouser from now on for these. Thsnx for the tip.
The other resistors I like are the 5W Mills wirewounds but I had one open up in PS dropping duty, a 1K, feeding the PI in my 50W '70s ODS at around 425V, so I don't use them in PS dropping applications any more, replaced it with a 5W sandbox, no further problems.
