Any ideas about the "Small Special"?
boldaslove6789
Re: Any ideas about the "Small Special"?
Post by boldaslove6789 »
Very Cool Tony!!! So it does have OD? Its good inspiration. Any clips?
talbany
Post by talbany »
Greg
Yeah it's a non HRM 124 style high plate w/PAB boost (Lift the stack) wired in rock mode only..Out for an effects loop.. No clips of that amp as it went out right away.. The Music Man KT-77 one I built for myself same config I kept I'll try and get around to some clips here shortly..FWIW I like the clean a little better on the MM and still takes pedals well... Thanks
Here is the back
ampdork
Post by ampdork »
That's a rad package Tony. Small box of whoop ass...
"...& I'm all out of bubblegum"
talbany
Post by talbany »
Greg
Forgot I had this..
Here is a clip of Jack Pearson playing the 22 watt version 2X6V's
Not as meaty but you get the idea..
http://www.youtube.com/watch?v=6qKiOg9U6gY
Pearson's Stone Cold!!
Let me know if I can help!!
bigmik
Post by bigmik »
jack pearson is sick, amp sounds awesome tony never thought 6v6's could sound so awesome .do you care to share any particulars of jacks amp without giving away all your secrets .
also is it a head with cab or a combo ,and what speaker is he useing
thanks
neil
Forgot I had this..
Tony[/quote]
talbany
Post by talbany »
Neil
Can't tell you too much got a partner.. I can tell you we ran the plate voltage on that amp around 440V and used the JJ' 6V's in there.. Also the NFB resistor is a 4.7K.. Skyliner stack stock.. I did modify the OD entrance a bit but can't remember what I did there..Sorry!!
The speaker he used in the clip is an Eminence Neo .. Not sure of the type since Chris at Eminence sent it to him.. I told him Jack likes the EV L's and if he had an equivalent to that in a Neo..If I find more I'll post it..I am pretty sure it's one of there PA speakers..Jack loaded the speaker in a single 12 cab I think an 806 copy.. The clip is with a single 12..
Wish I could help more!!
bigmik
Post by bigmik »
It's cool didn't expect you to get to explicit ,the amp does sound sweet
thanks
talbany wrote:Neil
