AN Wonderland/JM 100w layout
Bombacaototal
Re: AN Wonderland/JM 100w layout
I am wondering if anyone can tell me the make of those brown capacitors used in some parts of the Two Rock built? Are they NTE or CDE? Do they compare sound wise closer to a vintage Mallory chocolate brown drop or more towards a 6PS orange drop?
Also wondering what is the make of those dark blue cathode capacitor used on the reverb which have an arrow
Hey guys - I'm looking over the layout posted in the start of the thread, and I'm a bit curious about the placement of the gain pot.
Putting it all the way over on the left seems to run the signal wires for quite a long way.... a bit contradictory to how I alsways seem to read a golden rule about trying to go for shortest signal path, and keeping signal wires short.
Doesn't the length here just make it pick up extra noise?
Wouldnt it be smarter to put it next to the treble pot???
telentubes
I agree with you and I put the gain pot next to the treble on the 50 Watt that I built. I don't know if it made a difference, but I also thought it was a long run.
This circuit is so stable it doesn't make any difference on the location of the gain pot.
Yes there are long wires with wiring the pots but I used coax with no issues after years of use with my amp.
- norburybrook
I would echo that sentiment. My amp is as quiet as a mouse even with everything dimed.
M
M
- pompeiisneaks
- Site Admin
Yeah from my understanding long runs are 'bad' but only if you don't use shielded cable. The longer the run, the more chance the lead can pick up noise, bit if it's properly shielded, it removes that problem. Look at guitar cables, they can and often are VERY long with the most sensitive part of the signal, the part amplified the most, but that cable, being shielded, makes it a non issue.
~Phil
~Phil
tUber Nerd!
I personally like to drop the plate voltage to V1A to around 165vDC. Good trick for increasing the natural compression in the amp and making a pretty smooth amp just a tad smoother. Also, tends to give it a little more sweetness when the gain is cranked up. JM2C.
Also tweaking that 1M/68K voltage divider is a good place to start when voicing it for HB equipped guitars IMO. I typically just install a pair of trimmer resistors there and tweak until I like it.
Sent from my Moto G (4) using Tapatalk
Hi, I was curious what setting with 68k/1M voltage divider you preferred when playing with humbuckers .dbeasley wrote: ↑Sun Mar 18, 2018 8:16 pm I personally like to drop the plate voltage to V1A to around 165vDC. Good trick for increasing the natural compression in the amp and making a pretty smooth amp just a tad smoother. Also, tends to give it a little more sweetness when the gain is cranked up. JM2C.
Cheers
Guy
What brand preference for transformers do you guys use? Normal fender? Classic tone? Heyboer? Thanks!
Any of those have given very good results. Some swear old Fender iron sounds best; ymmv.
So this is basically an SSS axe Filters & CF Driver (002 also used buffers in the mixer section but I think only 002 used the tweed mixer)..
Contour is a VOX Cut control so there is NFB on the PI as well as on the grids (& V1) That's a lot of NFB (Is this amp a bit dark?).I would definitely experiment with the GNFB resistor to find which one sounded best in your amp.
The two things I would like to try is axe the contour and the master..You can always tweak the gain a bit at the 68k resistor off V1B.This would help open it up a bit I would think! (Blackface killer!)
Just my humble opinion
Thanks Taylor for the contribution really appreciated!!
Blackface killer it is for sure! Hands down my favorite clean+reverb amp circuit. It's very forgiving in terms of parts selection as well. I'd wager you could build one with used pinball machine parts and it would sound good.
I agree! Most clean amps like this one are generally more forgiving on the parts..Preamp style overdrive amps are another story!..IMO
Seasoned Old Kiss pinball machine parts are the ones you want!.
- norburybrook
Tony,talbany wrote: ↑Sun Mar 25, 2018 1:45 pm So this is basically an SSS axe Filters & CF Driver (002 also used buffers in the mixer section but I think only 002 used the tweed mixer)..
Just my humble opinion![]()
I messed about with that voltage devider as I felt it wasn't allowing enough gain. I also agree about the master. It's not a loud amp at all. I genereally have the master up full to get any kind of gig level from it. I have both the LNBF and global NFB on switches.
Marcus
Marcus
So with all the LNFB disconnected how would you compare it to something like a well oiled AB763 Vibroverb?..I already have a couple good sounding clean style amps ..Just wondering if I want to go here?
Masters never sounded good in Blackface amps anyway why would it work in this one?
IMO NFB loops and masters have a habit of sucking the life right out of an amp
