D Deluxe
lovetone
Re: D Deluxe
Post by lovetone »
I think Steve used fixed bias and set it to -30 volts reading through his posts
The 5E4 uses that method the 5G12 I think is also fixed bias.
mhartman
Re: D Deluxe
Post by mhartman »
[layout moved to files section]
Re: D Deluxe
Well you can use fixed bias cathodyne or cathode bias cathodyne PI but there seems to be more then stock PI circuit going on here and I actually am not sure unless I start modding and find out myself.
I was checking out the old/new Jim Kelly single reverb amps and his PI could be used too.
jelle
Re: D Deluxe
Post by jelle »
Nice layout.
Two things that caught my eye.
1) The .1 cap on the CF side is connected to both sides of the trimmer.
2) One ground is added between the brass plate and the V1 cathode ground point. I do not see that connection in the pics.
Great job!!
Jelle
mhartman
Re: D Deluxe
Post by mhartman »
jelle wrote:Nice layout.
Great job!!
Jelle
Thanks Jelle. Good eye. The layout has been updated accordingly.
Charlie Wilson
Re: D Deluxe
Post by Charlie Wilson »
Hello, that layout looks sweet. Need the jumper across the two input jacks.
CW
ToneMerc
Re: D Deluxe
Post by ToneMerc »
Only the primary output jack should be switched.
TM
Re: D Deluxe
M Fowler wrote:Well you can use fixed bias cathodyne or cathode bias cathodyne PI but there seems to be more then stock PI circuit going on here and I actually am not sure unless I start modding and find out myself.
You could do the fixed bias mod on this PI circuit and the effect should be to further delay clipping just as in the standard 5E3 PI. That would be an interesting experiment; it might become too clean.
mhartman
Re: D Deluxe
Post by mhartman »
ToneMerc wrote:Only the primary output jack should be switched.
TM
Charlie Wilson wrote:Hello, that layout looks sweet. Need the jumper across the two input jacks.
CW
Thanks guys! Updated.
Charlie Wilson
Re: D Deluxe
Hello, not to get too picky but Dumble unsoldered the self lead from the OT and ran it to the speaker jack.
CW
mhartman
Re: D Deluxe
Post by mhartman »
Charlie Wilson wrote:Hello, not to get too picky but Dumble unsoldered the self lead from the OT and ran it to the speaker jack.
CW
That's the kind of pickyness that makes this forum this forum. Thanks for that info. Updated.
Re: D Deluxe
I agree the better the detail the better the build results very nice layout.
Martin I'm going to be messing around with the PI soon. I like the amp built as shown in Charlie's layout and this updated layout, but I want to experiment some more. :)
67plexi
Re: D Deluxe
Post by 67plexi »
I'm in the process on the PI change and lower voltage PT. Let you all know.
We had a earthquake that took out the fiber optic internet under water cable.
I would like to personally thank all concerned for turning the thread around in a positive manner.
Steve.
dobbhill
Re: D Deluxe
Post by dobbhill »
I am so confused. Please guide me to a schematic.....I can't follow the content because I have no schematic. My apologies if it's in plain view, but hidden well.....
Thanks for all your contributions. I have original 5F11 and 5E3; both rough. I'd love to do before/after clips, but I need/want some guidance...please.
D
There are no stupid questions, just stupid people.......
Re: D Deluxe
dobbhill the original info is in this thread including schematics
https://tubeamparchive.com/viewtopic.php?t=25054
