Took the time to do some simple analysis around this question, assuming a reference case where a 15n coupling cap, a 100k series resistor, a 250k Drive pot are coming off the plate of OD1, and 100p Miller capacitance into OD2.talbany wrote: ↑Fri Jan 25, 2019 6:19 pmMartinmartin manning wrote: ↑Fri Jan 25, 2019 5:55 pm Could you not just turn the pot down and reduce the signal going into the following stage? I view the OD trimmer as setting the minimum amount of dirt you get from the drive in OD mode. I think frequency response going into OD1 is mostly about the series resistor feeding the trimmer and and the grid stopper.
Yes you could, however, the frequency response (knee) is still shifted. So you have to think of 2 things when you choose a volume pot?.Signal loss and Knee. So the higher value pot will add low mids (darker). As far as the grid stoppers go I don't think your really altering the sound that much below 220k. If there is? it's minimal 15.5kHz w/68K (in combo w/Miller capacitance).
Personally, I think the 220k grid stopper on V1b and the 220k OD input resistor are there mainly to help keep the low end tight.So it's really everything together.That's what I hear anyway!
I changed this before you read it in my last post so here it is again.
As far as the OD trimmer goes I usually set it for best frequency response (with the tube) and control the amount of gain with the drive pot. Then control the volume of the OD with the OD Level.But that's me!
BTW.This is why (I think) Dumble sets his trimmer rather consistently sets and puts it in the amp.He's setting the frequency response of the OD.Why else would he alter the pot value on 124 and 123?
In changing the value of the Drive pot to 100k in isolation, I see five things happening:
- The -3 dB point on the low end moves up ~17 Hz (you lose lows, 1-2 dB at 50 Hz, which could be made up by increasing the value of the coupling cap to 22n).
- The AC load on OD1 is increased, lowering the maximum available gain (at the output of the coupling cap) by about 1 dB.
- The AC load line rotation reduces the headroom on OD1, lowering the distortion threshold ("gainyness" in player parlance).
- The maximum gain at the output of OD1 is lowered by the voltage divider effect with the 100k resistor feeding the pot. If a 250k 10% taper pot is set at 25k (noon), a 100k 10% pot would have to be set at 14k3 (so something higher than its 10k noon position), to get the same attenuation going into OD2.
- There is a small increase in OD2 HF response due to the decrease in the series resistance of the top portion of the pot (-3 dB point moves from 11.8 to 13.3 kHz).
Grid stoppers and other series resistances, i.e. the top portion of the OD trimmer, and the 100k feeding it, affect HF roll-off through the Miller capacitance, without affecting low end response of the stage (OD1). In OD, the size of the trimmer will affect the low end coming out of the previous stage (Cl2) the same as as the Drive pot value affects OD1 bass (larger value means more lows). Larger values result in more series resistance in front of OD1 for a given signal level, reducing highs a bit. Dumble seems to have addressed that in more direct ways, including large grid stoppers and snubber caps. That said, I really don't see the OD entrance trimmer setting having much impact on frequency response once its value and the value of the resistor feeding it are chosen because it's set in a narrow range. There is little effect on the highs, and the setting won't affect the lows coming out of Cl2 at all. I'll stand by my comment above: where you set it is mostly about the OD distortion floor.
In the analog world it's truly "everything together" as you say above ;^)
