Faceplates for Hammond 16x8x2 chassis
IcemanB52
Post by IcemanB52 »
Attached are CorelDraw 4 files I used for my faceplates. I order these at http://www.bnplasers.com/. I've ordered 3 sets and their service is very good. Only drawback is that they use CorelDraw, which is not a widely used program. Cost for front and back was around $55.
markusw
Re: Faceplates for Hammond 16x8x2 chassis
Post by markusw »
IcemanB52 wrote:Attached are CorelDraw 4 files I used for my faceplates. I order these at http://www.bnplasers.com/. I've ordered 3 sets and their service is very good. Only drawback is that they use CorelDraw, which is not a widely used program. Cost for front and back was around $55.
Thanks a lot! 8) Your amp looks fantastic. Wish I could do wood work.
Is here any setup fee for the faceplates or in other words does it make a difference whether buy one set or three?
Peace,
Markus
Edit: I also like the outcome of home made Bungard Alucorex faceplates (see below)
If you're doing 3 pairs of plates it's pretty cheap. If you just do one set of plates out of a ~19x19" Alucorex plate like I did it's probably in the same league as the bnp plates. Problem is you also need tools to properly cut the stuff. I had to go to a local shop. They charged roughly $2 for one cut.
IcemanB52
Post by IcemanB52 »
I don't think there is a setup fee, but double check their web site for current pricing. Your amp looks great! Where did you find the schematic to add reverb?
markusw
Post by markusw »
IcemanB52 wrote:I don't think there is a setup fee, but double check their web site for current pricing. Your amp looks great! Where did you find the schematic to add reverb?
It's Gary's single tube reverb:
https://tubeamparchive.com/viewtopic.ph ... ght=reverb
