Is that a Carling 800 series? I've been trying to find a source for the carling 800-5, not the 5a, the A means it has on off position which I don't want. What you have pictured would still be better than the NKK alternative - I just wouldn't use one of the poisitions, is there a source for these?brownnote wrote:This is the closest pre-fab I've found:
World Power selector switch?
Re: World Power selector switch?
www.RedPlateAmps.com
tonelab2 wrote:1 3/16" will work - aren't those expensive? or do you have a good source?heisthl wrote:
I have Marshall style 6pos, 100v 120v 200v 220v 230v 240v, 1 3/16" hole cutout type. Can send you a few if you like.
tonelab2 wrote:
Where do I get this type? thanks
I found those at TAD.heisthl wrote:Is that a Carling 800 series? I've been trying to find a source for the carling 800-5, not the 5a, the A means it has on off position which I don't want. What you have pictured would still be better than the NKK alternative - I just wouldn't use one of the poisitions, is there a source for these?brownnote wrote:This is the closest pre-fab I've found:
Seems like there'd be a domestic source, but I haven't found it yet.
Maybe it's surplus?
That would work.tonelab2 wrote:I have Marshall style 6pos, 100v 120v 200v 220v 230v 240v, 1 3/16" hole cutout type. Can send you a few if you like.heisthl wrote:I found the NKK HS16 series but it's over 2" wide and won't fit in the chassis I want to use. So the NKK HS13z will have to do - it's only 4 position ionstead of 5 (mouser 633-HS13-Z-RO)
Where do you get those?
Granger has the Carling 800-5A in stock at less than 8 bucks. Any one know how to get the 5 selections (100,120,220,230,240) out of an off-on-on-on-on switch? Actually maybe there really isn't an off position according to note2 in this document:
sorry stupied question.... thanks for the help!
My Daughter Build Stone Henge
