Ben Harper in July 2009 GP
rmb550
Post by rmb550 »
Quote:
GP: Are you using similar gear now that you're on the road as Relentless7, or has it changed since the sessions?
Harper:Dumble made me a 100-watt Overdrive Special combo from scratch. It's a new step for me sonically because it offers a preamp boost for both the clean and the overdrive sounds. It's like having the most otherworldly overdrive pedal built right into the the amp.
Is Dumble still building ODO combos?
Guitarman18
Re: Ben Harper in July 2009 GP
Post by Guitarman18 »
Curious and curiouser,
Fretboard Journal wrote:
We also show off some of Harper’s favorite gear, including his Weissenborns, Dumble amp #109 and the new Martin signature model he has.
If D made #109 for Ben Harper, he must be a lot older than he looks! :wink:
http://fretboardjournal.com/blog/?m=200808
Cheers, Paul.
rmb550
Post by rmb550 »
The whole GP article talks about a number of Dumbles that Harper uses and where he got them from. But the quote seems to reference a new build. I am also curious about his PAB statement - I understood that PAB was functional whether the OD was engaged or not - or am I missing something?
rmb
The PAB should work on clean as well as OD.
It just lifts the tone stack so it removes that loss and boosts the volume.
johan
Post by johan »
How many Dumble's has he got now? 3 or 4?
I know he's got a combo and he used this head/cab thing when I saw him in December.
[IMG:1024:633]http://i279.photobucket.com/albums/kk15 ... G_1361.jpg[/img]
