Check my loop
Check my loop
I have made a loop layout for mt Dlite.....does this look ok? Did I miss anything?
The Blues is my Business....
and Business is good.....
Re: Check my loop
The cathode bypass cap on the recovery amp is a 47uf not a 5uf. The cathode resistor is a 1.5K (although I have seen 1.3K and 1.625K as well). The feedback loop has a .22uf cap.
Later stereo Dumbleators use a .1uf on the feedback. But, they use a smaller send pot and have a higher knee there. You could try a 100K send pot with a .1uf cap. That may be nice with the .1uf feedback loop.
Re: Check my loop
Thank you ears....you saved me some work
Re: Check my loop
Great work! For a stand alone unit you may want to include the bright switches. IMHO it works best if you remember to use audio taper pots.
I think it's a really nice, well thought out layout - Ok if I steal it?
www.RedPlateAmps.com
Re: Check my loop
Another quick question
....what voltages should I be looking for at the plates?
- glasman
Re: Check my loop
It depends on your supply voltages,
But normals are
Recovery side in the 190 to 220 range
Cathode follower 250 to 280.
Gary
But normals are
Gary
About 5 miles south of I-94
www.glaswerks.com
www.glaswerks.com
