2 rock custom reverb
paisley_tele
any one got the lay out for one of theese amps two rock custom reverb . or is the an amp close to one that i cound build
- phsyconoodler
Re: 2 rock custom reverb
They are pretty much the same as dumbles and D'lites'.I am not a big fan of the tone from the Two Rock.Only played a couple though,with no time for tube swaps or tweaks.
Crystal latice or vacuum,that is the question.
try this
This should get you close...
https://tubeamparchive.com/download/file.php?id=6097
Larry (Novosibir
) posted a schematic for a two rock with reverb a while back. You should be able to find it in de Dumble Discussion section.
Have fun!
Jelle
Have fun!
Jelle
I've attached my pencil drafted schem once again. Unfortunately I haven't had enough time yet, to draft it w/ ExpressSCH, but hope, that this is of some help so far.
Larry
Larry
Larry's Website now with included Pix's Gallery
Noob question: are the V2a and V2b cathode bypasses wired correctly on the PDF? Seems like V2b grid and cathode are connected directly.novosibir wrote:I've attached my pencil drafted schem once again. Unfortunately I haven't had enough time yet, to draft it w/ ExpressSCH, but hope, that this is of some help so far.
Larry
mat
They're not connected - what you're seeing is the snubber (470 pF!!!!!
) between plate and cathode. It looks like the photocopier didn't do a great job of capturing it.
no thats clear. There is a connection between the grid and cathode on V2B. Have a look.
Oh, now I got it, thanks dave g !dave g wrote:They're not connected - what you're seeing is the snubber (470 pF!!!!!) between plate and cathode. It looks like the photocopier didn't do a great job of capturing it.
How about of the reverb circuit, what is going with the V3 + V4a ?
mat
No, there isn't.JimiB wrote:no thats clear. There is a connection between the grid and cathode on V2B. Have a look.
Do you see those huge heavy dots littered everywhere else across the schematic that indicate connections? All I see between the grid and cathode is a tiny bit of extra ink where the pen crossed a previously drawn mark and was subsequently photocopied.
If the grid and cathode were jumped together, there would be no bias voltage on the grid and the tube would not operate!
Similarly with V2a, the schematic makes it look like Ck is coming off the plate after the 470pF snubber. If you look closely enough you can see a very faint line coming off the cathode above Rk that got lost in the photocopying.
Ah so the plate is connected to the cathode via the 470P cap and it crosses the grid but dosent connect because there is no dot. Correct?
Sorry for being daft.
Spot on
The Reverb circuit is a standard Fender design as seen in most of the BF & SF Fenders, therefore I've drafted it as a block.mat wrote:How about of the reverb circuit, what is going with the V3 + V4a ?
Larry
Ok, thanks Larry !novosibir wrote:The Reverb circuit is a standard Fender design as seen in most of the BF & SF Fenders, therefore I've drafted it as a block.mat wrote:How about of the reverb circuit, what is going with the V3 + V4a ?
Larry
mat
