I think I am finally done with my amp. You can see my previous posts which show the amp inside and out. The only changes from before are that I finally added the relays to switch things in and out. I also added a mid-boost switch on the back panel. My previous posts with clips were all done with humbucking guitars. The attached clip is with the treble on 7, no mid boost, od on with drive set at 11 o'clock and level set at 1 o'clock, PAB off, and using a telecaster with Bill Lawrence PUs. I tried to see what I could get with a cleaner and brighter tone. I can easily get the fat midrange sound.
The amp is based on the D'Lite schematics online using Heyboer transformers, Winged-C 6L6s, EH 12AX7s, and 21kohms on the gain pot. It's non-HRM.
I hope you enjoy the clip.
ODS Done
drpastorbob
ODS Done
