Music Man Power Trannies anyone
I picked up a few of these MM Power transformers 200-130-250) from a repair shop at a Guitar Center going under here in Rockville Md.. Ive heard somewhere that Dumble used these in some ODS when MM went under... Am looking to do a non Hrm with it... Anyone use these trannies or play an ODS with these transformers... Or should I not even bother...
Here are the specs.. Any comments would be greatly appreciated
Primary 120v
High Voltage Sec #1 Sil Voltage Doubler (F.W.) (2) 100mfd
Brn- R/Y 710vdc @ .100a, 660vdc @ .275a
Red- R/Y 440vdc@.275a
Low Voltage Sec #2 org - yel- org
Sil. Bridge (2) 150 mfd cap + - 42 V 0A 60V CT @ .1 RMS
Filaments (2) 6.3V @ 6 A grn- grn/yel
Tony VVT
Primary 120v
Tony VVT
Re: Music Man Power Trannies anyone
Best non HRM tone I have ever heard. 700V MM iron.
[img
756]http://www.scottlernermusic.com/pics/BludotoneFront.jpg[/img]
[img:937:624]http://www.scottlernermusic.com/pics/BludotoneBack.jpg[/img]
[img
Are you mentioning these for info - or for sale??
You would be advised to do a build with them. Love my D-clone with MM iron.........
REALLY!!!!
That's interesting I would think it would lean on the bright and harsher side.. especially in OD.. Thanks Scott for the Pictures...Well I'll just have to go here...I got several of these Trannies I'll go through them and if I have any extra I'll post them here first at a reasonable price... Thanks
Tony VVT
Tony VVT
bluesfendermanblues
Isn't MM = Mercury Magnetics ??
If so, it is alive and kicking www.mercurymagnetics.com and they do have fine Iron. I've used the FTBO-MM bassman for my ODS50. Fine piece
Music Man!!
- Funkalicousgroove
I use these all the time, they sound great- I actually have custom PT's made up to fit my chassis, but I use the RD-130 output trannies as well-
they are not bright or harsh at all, one of my personal favorites!
Thanks Brandon... Sorry I missed you @ the Amp show I heard your amps crushed...I want to play one sometime...I am going to try and build it in this little head... 2 EL-34's with 700 volts on the plates dissapate 70 80 watts...going to try and fit the hybrid in this little thing most likely have to put the OD Drive and Level controls on the back...Wish me luck..
Awwww.... That's a cute amp what is it..... Not much just an 80 watt Hybrid Model Overdrive Special... I take it with me for these little events like this one..... Oh do you know where the bar is!!!! LOL!!!
- Funkalicousgroove
Actually, we did chat in the elevator after the show, and the next morning out front
Make sure you look at the load lines for this type of plate voltage, I think you'll find that a pair of EL34's are going to want to see a much higher plate to plate impedance at that kind of voltage, My guess is around 9K-
The MM's also run the screens at 1/2 the plate voltage-
Brandon
Brandon
Do a non-HRM and use an internal IM trim for the volume and set it to 5, use a .02 treble cap (full time mid boost)use a 100k to ground for the Ratio, have OD on all the time (no relays). If you tweak the OD right it will be clean with the drive at low settings and everything can be on the front. If you want a really small main board layout let me know.talbany wrote:Thanks Brandon...I am going to try and build it in this little head going ....most likely have to put the OD Drive and Level controls on the back...Wish me luck..
www.RedPlateAmps.com
Brandon... you spoke with my partner Jim or maybe Bill... Thanks for the Tips.. I my PM you with a few more tips....
Also Thanks Heisthl I am going to try for the whole ball of wax but may have to do your version...I just found a 2nd MM the 130-- do you think this would be a better one for this build or the 200---
Thanks Everyone
Tony VVT
Thanks Everyone
Tony VVT
- Funkalicousgroove
It may have been Jim, he had a beard and a southern accent- nice fellow, I'm AWFUL with names.
bluesfendermanblues
Ok oktalbany wrote:Music Man!!
