My amp still does not sound good...
Tweedle Dee weak output
Re: Tweedle Dee weak output
So after trying 300 ohms as a bias resistor, which made very little difference in the dissipation (2%), I swapped out the GZ34 for a 5Y3. This lowered all the power section voltages but it got the plate dissipation down to 92%. Amp is less powerful but only by a little, and the tone seems to be the same as far as I can tell. I suppose this is a comfortable combination and supposedly I'll get more life from the 6V6's. Now to spend some time playing it!bepone wrote: ↑Sun Aug 29, 2021 1:49 pm means, over the max dissipation of the 6V6.. if we assume g2 current is cca 4-5mA, then anode current is around 37mA, Padiss =13.5-14W, still is over normal biasing range of 65-70% of max dissipation /6V6 has anode dissipation od 12W, JJ claims 14W
tonewise you are close/or you are in/ class A so your amp dimmed will not go in farting blocking distortion, or will but effect will be reduced, which is good, but from dissipation aspect , 6V6 is working on 110%, and their life will be shortened due to excessive heat.
current can be dropped in two ways, reducing voltage on g2 grid , Vg2 , inserting resistor of 500-1000ohms 5W in Ub+ line going to g2,
or incresing cathode resistor for cca 30-50 Ohms doesnt matter the value, just to choke little bit anode current.
Phil
great, yes, 5Y3 have bigger voltage drop..GZ34 are not dropping too much, also with 5Y3 and hard strumming you'll get more compression
