D-Lite redux - an unintentional manifesto
- Funkalicousgroove
Re: D-Lite redux - an unintentional manifesto
I think it is more of a utilitarian approach, but I also think each part was tested. There seems to be alot of military surplus parts, and blister-pack(NTE, Radio shack, Sprague) parts, so my guess is he used what was available.
Very nice build!
Forgive my ignorance, but what cap and resistor are meant with the "0.01uF/250k midrange setup "?
The very first cap on the board on the preamp side?
Wow, I know you've been working on that amp for a while.
I heard amongst the builders in different forums mention that the amp takes a journey before coming into it's own.
Funny how that works.
Congrats on the great build and sharing.
Yes, the 0.01uF replaces the stock 0.05uF that connects the the Midrange control. The 250kA Midrange potentiometer replaces the 100k control.tsl602000 wrote:Very nice build!
67:1
Fab looking build - tons of great info.
Thanks!
Thanks!
Thanks for the info kleinm! I could figure out the cap but never thought about the pot...
Wow!!
Really nice... inside out...
Nice looking amp, for sure! It sounds like you've spent a lot of time and effort to get it to where you want it.kleinm wrote:Lowering the coupler off CL2 to 0.02uF helps remove some bottom end hash.
What is CL2, and what is the coupling cap off that? It seems to me that too much bass is making its way into the overdrive section on my amp, and I think that's what you're addressing here.
-g
groovtubin
two .047`s in series is HALF the capacitance!greiswig wrote:Nice looking amp, for sure! It sounds like you've spent a lot of time and effort to get it to where you want it.kleinm wrote:Lowering the coupler off CL2 to 0.02uF helps remove some bottom end hash.
jim
Kleinm, you mind telling us what you are biasing your 6L6's at?
Approximately 33-34mA idle current. I'm not sure why, but I prefer the sound with a slightly colder bias on this amp....
67:1
Jim,groovtubin wrote:two .047`s in series is HALF the capacitance!greiswig wrote:Nice looking amp, for sure! It sounds like you've spent a lot of time and effort to get it to where you want it.kleinm wrote:Lowering the coupler off CL2 to 0.02uF helps remove some bottom end hash.
What is CL2, and what is the coupling cap off that? It seems to me that too much bass is making its way into the overdrive section on my amp, and I think that's what you're addressing here.SO the OD entrance is getting trimmed...
jim
I believe it, but my question was to kleinm because he seemed to think (as I do) that it may not be trimmed quite enough.
Is CL2 referring to V1b? And is the coupler you're suggesting changing to .02uf one of those two .05uF caps?
-g
Yes, CL2 is just another name for V1B. The coupler I changed is the 0.05uF that is connected to the V1B plate. I lowered that to 0.02uF.greiswig wrote:[
Jim,
67:1
A while back I was trying to get maximum clean headroom out of the standard PI/output circuit(s). The platform was using 200ma Fender PT and Fender Prosonic 50 Watt OT. Without using my ears and just using the scope I got maximum power at 1500 to 6000 hz using the lower value screen resistors(470) and higher grid resistors (5K1). Once changed the amp sounded better too.... You can see the difference on a scope. Using the smallest value PI input cap you can stand also boosts clean headroom.Funkalicousgroove wrote:I can't believe you can hear the difference in 470 ohm and 1K screen resistors!! I can't !!
www.RedPlateAmps.com
Thanks for the report.
