https://www.musicradar.com/news/under-t ... ve-special
Sent from my iPhone using Tapatalk
						Robben Ford talks about his amps
- Paul-in-KC
Re: Robben Ford talks about his amps
Thanks for posting!
interestingdariez75 wrote: ↑Sat Jun 16, 2018 3:07 pm https://www.musicradar.com/news/under-t ... ve-special
   thanks
Always a pleasure [emoji12]
Interesting article. A couple of things I noticed:
"This amp is currently fitted with JJ 6L6 GCs, but they were originally fitted with Philips 6L6s or Groove Tube 6L6s. Sometimes Mr Dumble even used the highly prized and rare Philips 7581s, which are a hard-to-find, super-high power variant of a 6L6."
I don't know if an additional 17% of plate dissipation qualifies as "super-high power," and this statement might suggest to some that the amp's power output is increased with 7581 tubes, which of course is not the case.
"Robben rarely uses these [the loop jacks] now, but he has used the Dumblelator to sync with a TC 2290 Delay unit. If the sockets are not used it seems to sound nicer with a short patch cable inserted."
Sounds like the return jack needs some cleaning...
"The Deep switch can get way too big if used at loud volumes; the Rock and Jazz gives the player the choice of either dead clean (Jazz) or big and dirty (Rock)."
Deep is Mid-boost, of course, and Rock doesn't have to be dirty.
RF has never been much for technical details (no disrespect!), but it doesn't seem that the author is either.
In a earlier interview, about the time Robben ditched his Dumblelator, Robben found his #102 too bright without a dumblelator. They contact Mr.Dumble and he suggested a cable in the FX loop. As I recall correctly this "short" patch cable was about 6ft. High impedance FX loop + 6ft cable=roll off high.martin manning wrote: ↑Sun Jun 17, 2018 3:31 am
Ah, I see, a missing technical detail ;^) So that's 100-300pF to ground, going into the PI (no D'Lator). It's really the Zo of the last preamp stage, and much more importantly where the master volume is set that determines the roll-off.
