As fate would have it I just bought a Peavey Festival (Deuce). The iron is a fair bit bigger than the usual Fender option.
Does anyone know the specs for these transformers?
Aaron
Overdrive Special build
Re: Overdrive Special build
You can get the schematic for those amp below: afaik there are 2 kinds of setups. The 4X 6L6GC or the 6x 6L6GC (mace)Aaron wrote:As fate would have it I just bought a Peavey Festival (Deuce). The iron is a fair bit bigger than the usual Fender option.
Aaron
http://music-electronics-forum.com/t33321/#post306082
larsvictor
Peavy Festival is the "head only" version of Deuce II. Solid state preamp and 4 6L6GC poweramp.
PT should be EJ175. TAD replacement has the following specs:
MAINS for: Peavey® Deuce 240T, 120W, replaqces transformer EJ175
Primary:
0 V White
115 V Black
0 V White
115 V Black
Secondary:
0V Red
370 V Red
0 V Yellow
50 V Purple
0 V Orange
6,5 V Brown
Primary:
0 V White
115 V Black
0 V White
115 V Black
Secondary:
0V Red
370 V Red
0 V Yellow
50 V Purple
0 V Orange
6,5 V Brown
Irwin
Just wondering if you had had the amp back to fit the front panel? if so did you investigate the interesting feedback you mentioned?
Not yet, faceplate arrived finally. In 1-3 weeks the amp is here for fitting the frontpanel and some measurements, pics etc.
Looks good
i like the minimalist look, I just had a diezel big max in for repair that has the same idea the face plate is very simple and clean looking.
