5/16 Tip Jack Part Number
Smitty
Post by Smitty »
What tip jack are you using in the CE chassis for bias test points?
5/16" (.3125") D-shaped hole.
After an hour of searching this site and the Internet I'm waiving the white flag. :(
Re: 5/16 Tip Jack Part Number
Standard banana jack.
dorrisant
Post by dorrisant »
deleted
ToneMerc
Post by ToneMerc »
Here's what I was using in those chassis, Kobicon 164-R116B & 164-R116R
http://www.mouser.com/ds/2/209/KC-301107-199024.pdf
TM
UltraHookedOnPhonix
Post by UltraHookedOnPhonix »
ToneMerc wrote:Here's what I was using in those chassis, Kobicon 164-R116B & 164-R116R
TM
Those are non-stocked at Mouser I'm afraid.
These Keystone parts looks like a viable alternative:
Mouser part#: 534-6091 (red)
http://www2.mouser.com/ProductDetail/Ke ... 9ODiwme4hs
Mouser part#: 534-6092 (black)
http://www2.mouser.com/ProductDetail/Ke ... c7gYOuapbc
Hoffman Amps has those available for sale.
MakerDP
Post by MakerDP »
Smitty
Post by Smitty »
Thanks for your input guys but not looking for banana jacks or other size holes. Need a tip jack to fit a 5/16" (.3125") D-shaped hole. If anyone has a source I'd really appreciate it.
ToneMerc
Re: Thanks
Post by ToneMerc »
Smitty wrote:Thanks for your input guys but not looking for banana jacks or other size holes. Need a tip jack to fit a 5/16" (.3125") D-shaped hole. If anyone has a source I'd really appreciate it.
The Kobicon part numbers that I referenced and have used were taken from the CE chassis CAD drawing, which obviously is setup for the larger form factor banana plug. You will have a hard time finding a 5/16" D mounting pin/tip jack as that mounting is normally .250.
As UHOP mentioned that Keystone part appears to be a compatible replacement for the Kobicon, but if you have your heart set on only a pin jack, then good luck.
TM
ToneMerc
Post by ToneMerc »
He wants the pin/tip jack, not a banana jack.....that's the issue.
TM
glasman
Post by glasman »
TM
Look on Mouser, they have the Kobicon jacks and I am pretty sure they have both banana and pin style.
This would probably work...
http://www.mouser.com/ProductDetail/Joh ... 6O436Zw%3d
Gary
About 5 miles south of I-94
www.glaswerks.com
glasman
Post by glasman »
Here is the drawing. Looks like it will fit the bill.
www.glaswerks.com
That part # drawing still looks to be 1/4 to me not 5/16.
