HRM Bypass
Blindog
Re: HRM Bypass
Post by Blindog »
ToneMerc wrote:
Blindog wrote:
*Edit- Just noticed it was linear taper. I was gonna replace my Level pot with this...think it'll be ok?
Sure, although if you have coax soldered to the pot back you might have to redo both strands. If not, you are golden.
Also,since it's a D shaft you might encounter a small issue of how the knob set screw will index. I have converted D shafts by inserting a shaft bushing and filling the void with epoxy.
TM
Ok, cool. I asking because my level pot is audio taper right now. I keep some JB Weld around for that kind of stuff, but I like the bushing idea better...less sanding to shape it.
Thanks for the help gents!
