Hi,i understand that with the relay switching the PAB must break the bass input from the wiper.
I think the drawing that i have is not doing that.
Does anyone have a drawing  where i can see how the relay is supposed to be wired?
Thanks in advance,Ed
						little help needed with relay switching
				Ed de Jager
Re: little help needed with relay switching
Wire it just like the 101 schematic's switch, bear in mind that on a relay  you have 2 pins by themselves on one edge for the coil, the next 2 pins are the common (which is the center pins on the 101 schematic's switch and are tied together and connected to P1 of the bass pot)the next 2 are the normally closed (arrows point to them on the schematic one of these goes to pin 3 of the trebel pot and the other to the bass pot p2)) and the last 2 are the normally open (these are NOT CONNECTED)
www.RedPlateAmps.com
				Ed de Jager
Thanks(i will have to read it over a couple of times though;-)
Ed
						Ed
