If Dr.D was using goop as a fastner, the amps which were gooped could withstand operation during a 10 richter scale earthquake with that amount of goop-age.. A minimal amount of that RTV/Silicone goes a long way as many of us know.
As for protection, I think its pretty common knowledge that a multitude of methods exists to remove the goop, heat,cold, solvents, even if the parts are destoryed in the degooping , as long as you can read the values and solder in replacements theres no loss (within reason of what part it is..) With that being said I never understood the goop as a protective measure. If you really don't want anyone inside your amp then weld a hardend 1/4" stainless plate to the top off the chassis and force the user to literally destory the amp to get inside it.. Or rig it with a claymore or something (sarcasm!)
As an isolator the goop would be good to a point. If your build had any issues with microphonics the blob could be a problem. As far as servicing, good lord WHY!!!!!!! I personally dispise dealing with gooped stuff, had to degoop a few pedals last year to fix them and it took 2-3 hours to get black marine epoxy off the pcb's to then have to rebuild 1/2 the unit..
Great build Jelle, these photos are more inspiration for the driving force of 3am building sessions
