TR Eric Gales- based off a Dumble circuit?
MrFender
Post by MrFender »
I own a TR Eric Gales and would like to know if and where this falls in the Dumble lineup. I prefer the sound of this amp over other TR's I've owned in the past like the 10th Anniversary and a Custom Reverb Artist. These pics were taken from someone selling this amp currently on TGP.
Is this circuit based off a specific Dumble model or did TR go a different direction. The amp is 50 watts, EL34, but can apparently also run 6L6's.
ToneMerc
Re: TR Eric Gales- based off a Dumble circuit?
Post by ToneMerc »
I'm thinking 50W HRM for the core topology. I guessing V7 has a solid state plug in rectifier, because obviously V8 is a tube rectifier. Is there a rectifier switch on the back.
TM
MrFender
Post by MrFender »
No switch on the back. Amp uses two 5AR4 rectifier tubes
dreric
Post by dreric »
The tube rectifiers are very non-Dumble but I've heard the the Gales TR is kind of a Marshall Dumble mix-up.
Can you give us a clearer picture of or write out the transformer code/writing?
Gales is one of my faves.
Eric
Eric
1949 Zenith, Zenith Toggle Recoil, Zenith 55 & 440
jelle
Post by jelle »
Yes, HRM variant.
MrFender
Post by MrFender »
It absolutely has a Marshall sound. I A/B'd it with my 50 watt 68 Plexi and it is very similar. The overdrive sounds like a germanium fuzz to me when cranked. Also kind of a butler tube driver EJ tone.
ToneMerc
Post by ToneMerc »
dreric wrote:The tube rectifiers are very non-Dumble but I've heard the the Gales TR is kind of a Marshall Dumble mix-up.
Eric
TR part number codes
Marvel(989) is the manf of the choke/ OT and the PT is from one of their other companies (166)Magnetic Components.
TM
amplifiednation
Post by amplifiednation »
Eric
Althhough rare, I've played a 100w HAD modded Showman with two rectos. And it sounded sweet. It was in one of those German hardwood boxes, I ended up building a suede cab for that amp.
Amplified Nation
www.amplifiednation.com
@ampnation
halfbackstrat
Post by halfbackstrat »
I've noticed a few of these TR's have tube rectifiers, the Matt Schofield one, the Exo 15 (perhaps an exception) and the Custom Reverb is available with it as an option.
Anybody got any guesses as to the construction of these tube rectifier circuits? I've never really looked at them before.
Also, interestingly, if you look at the gut shot of the MS model on proguitar, the bias pot is still between V7 and V8, despite the tubes being paired up as V6&7 as power and V8&9 rectifier.
Matt
