What year was ODS #183 built?
- David Root
I searched for this but came up empty.
I have an opportunity to pick up a Magic Parts TF-170 OT which it would be nice to change out the Mag Components one in my 183 with. But I know Magic Parts changed manufacturers at least once and I want to make sure I get the right one!
Can anyone help me out? I looked for pics of #183 and couldn't find any.
Re: What year was ODS #183 built?
David, #183 used a Pacific-TMI made #1052 EIA code OPT.
The Later Magic Parts transformers changed to Thordarsen EIA code #238
Steve.
Steve.
				PaisleyTube
				PaisleyTube
Too bad HAD doesn't sign and date his chassis.
He probably has the serial numbers recorded, I'll call him and ask...
The thing is by all reports he would sometimes not finish a build but finish later numbered amps so the serial numbers don't necessarily define a date.
To illustrate, #182 is HRM 6L6.
- David Root
Thanx guys, so if the one I'm looking at is 1052-XX-YY it's the right one.
1052(Pacific).....yepDavid Root wrote:Thanx guys, so if the one I'm looking at is 1052-XX-YY it's the right one.
TM
started out around 1986 finished somewhere around 1989 ballpark
Tom, AFAIK he signed and dated many of his chassis (see attached picture). And the date codes on parts (electrolytic caps, transformers, potentiometers etc.) provide at least the information when at the earliest he finished an amp.Structo wrote:Too bad HAD doesn't sign and date his chassis.
Picture source: https://tubeamparchive.com/viewtopic.ph ... 205#129205
Max
Hi , where I can buy one of this Pacific Trafo?
