Dumble Rig Quazi stereo
qtone
Post by qtone »
Great amps together the SSS and ODSR..
When both amps are in rack and ground control is back up and running
it should be a fun rig again.
I note some pedals are very noisy. ts9+ was real noisy not sure whats up but might switch back too 9vlt on that one see if its caused by power supply.
Large hum and noise coming from that screamer.
The SSS amps are finicky with pedals.
I need to research more of what the tried and true is with these heads.
The SSS loves strats and It can love humbuckers too.
Its one I keep wanting to turn back on and play.
Rings like a piano and anything at all that does not sound good
will show itself pedal wise or technique wise.
Anything that does not sound great through it will go bye bye
Some things sound fine through other amps and not this one
so just wont be pairing those.
Ground control here I come again...
Using George L cables and they sound superb with these amps.
