FET Boards
ckpop
FET Boards
Post by ckpop »
Hey can any point me in the right direction on someone in here that sells the Dumble FET preamp board or even a load board would be a plus
Carl
Re: FET Boards
If you can't find a FET pcb, you can make a simple eyelet board that will work just as well.
But if you don't have the scrap piece of garolite and eyelets, it would be expensive to get just the parts for that.
sonicmojo
Re: FET Boards
Post by sonicmojo »
I ordered a batch of wired FET boards from Ceriatone at one point last year and I've got 5 spares left. It has a PN4416A FET which I think sounds great and I've used them in a couple of different amps but you can always substitute whatever other FET you want to put on it. I'll ship one to you for $SOLD. Same goes for anyone else who needs one until I run out (US address). Send me a PM if you want one.
EDIT: They are all gone!
Bryan
ER
Re: FET Boards
Post by ER »
cheapo tip of the day-
Go to the home despot kitchen cabinet department, and when no one is there to help you (as usual) grab a few formica samples; various finishes and 2"x 2.75" perfect for tucking up into the side of the chassis. Free shipping. Cuts with decent scissors.
When you order parts get a few hundred eyelets from mouser in the 1/16" size so you can do FET and relay boards too in formica.
wjdunham
Re: FET Boards
Post by wjdunham »
ckpop wrote:Hey can any point me in the right direction on someone in here that sells the Dumble FET preamp board or even a load board would be a plus
Carl
Jason over at agb has all the boards you would need for a complete Dumble build, including the FET boards, I use 'em in all my builds.
http://agbamplifiers.com/
Bill
