Thanks Gary
Diodes on 12v Relay supply
If someone could prod me in the right direction on this i would be greatfull, not sure what i really need
Thanks Gary
Thanks Gary
Re: Diodes on 12v Relay supply
Any of the 1N400x series diodes can be used. Stocking the 1N4007 makes it easy as you can use the same diode for the HV power supply.
TM
TM
Cheers TM, i thought this might be the case but better safe than sorryToneMerc wrote:Any of the 1N400x series diodes can be used. Stocking the 1N4007 makes it easy as you can use the same diodes for the HV power supply.
TM
