Today I was measuring voltages inside my 100w ODS clone and specifically
I wanted to check the power tube plate voltage and the screen voltage.
As I was probing for pin 3 I slipped and a big spark arced, bang!
NOOOO!!!!
So now when I turn on the amp I get a loud 60Hz buzz.
I should know by now to clip on the test leads rather than probing those high voltages.
So on to the troubleshooting.
I first swapped out the tubes to eliminate those.
Still a loud buzz.
I found when I pulled V3 the P.I. tube that the noise went away, dead silent without that tube.
I measured a few more things but didn't see anything wrong yet.
So I decided to take a break and took the wife to the grocery store.
I got to thinking what could have been damaged when I shorted that plate to the heater.
This amp has 100R ohm resistors for an artificial center tap on the heater circuit.
So I put the ohmmeter on those and they are open.
No continuity, nada, fried.
So I will hunt through my parts drawers and see what I have.
I measured 6.8vac before which is a touch high.
It's within the 10% tolerance for heater supplies.
But the closer to 6.3vac you are the longer the tubes are going to last.
