Does any one have a source for 270pf disc capacitors? I find these hard to get hold of as the preferred values for most suppliers are 220pf and330pf
Geoff
270pf capacitors
Re: 270pf capacitors
In a bind, you could parallel 220p & 47p ....... or 250p & 22p.
With respect, 10thtx
Here:
http://parts.digikey.com/1/parts/79331- ... 71kbp.html
They have them for 500v also.
Al the best.
Al the best.
Horacio
Play in tune and B#!
Thanks for your help it seems they only stock the 3Kv type which willbe o.k I have parelled two values but would he happier using the correct value.
Thanks Geoff
Thanks Geoff
Glad to help, I had to use the parallel method, was not economical at the time to order just the caps. Does not look as neat, but works just as well.
All the best.
All the best.
Horacio
594-S271K43SL0N6TK5R at mouser
www.RedPlateAmps.com
Many thanks I'll check with mouser
Cheers Geoff
Cheers Geoff
