I have finally found some time to start mocking up my ODS clone. It has only taken 12 months! Built 4 amps since then! LOL
The cab is my first attemp at Dovetails. They are on the side!
My Cab builder flaked so I used it as an excuse to buy some wood working tools! I even bent up my own chassis on my brake and it shows!
So you have to picture the following:
I am respraying the front gloss black with white lettering. The current finish is a Hammerite. (I know it will be a bitch)
The front with a matching color 2 inch strip of wood underneath the chassis with a tan basketweave below.
The back will have a 6" wood piece from the bottom partially covering the tubes and hiding the reverb.
Final shots are about a week away! Any comments or suggestions are always welcome.
