Hi Tony,
thanks for your input.
The mods I did followed the problems I had:
1. too much treble (this came out when playing loud and over a 4x12 having 2 V30s (I know, not the best Dumble match) -> upping the OD input pot
https://tubeamparchive.com/viewtopic.ph ... c&start=15
I tried the amp with my 1x12 EV and at higher volumes and the OD was mushy/woofy. This was with the circuit as posted (100% original apart from PI coupling caps: 0.1uF).
2. in came the OD Bass cut mod (Ayan mod).
3. changed to 0.05uF PI coupling caps (sticking with 0.02uF PI input cap as per Scott's recommendation)
Still some piercing high content so next step was
4. Ayan Treble cut (HF trim) (250k, 0.001 uF cap)
Better sound in the high freq compartment in OD
Clean is great as was from the beginning
then I put a 47pF cap across the V2b anode resistor, but this I threw out again since I did not do much good to the sound after some serious testing
5. tried a pair of EL34s: better high mids, but since this is a 100W amp and the PT is from a Fender PA100 (Twin PT) I am stuck with using only 2 EL34, so I put the TAD 6L6 STR back in again
6. going back to 100k OD input trim (much better in the bass, set to close to 23k)
7. tried 100k Level (= OD content) by paralleling 220k with pot, but I loose too much OD for my taste
I could play around with the 180k series resistors, but I would get away more and more from the original #183. That is why I think (and wrote) that the iron use has a vast influence on the amp. Me thinks one has to choose the correct schematic for a specific set of iron used.
My other amp (HRM using Hammond OT never was as problematic as this amp using Schumacher OT and Fender Twin PT. Voltages are dead on btw.
The LNFBL was installed all the time (switch with 22M, 44M or off), but I seem to like the LNFB off in clean and at 22M or 44M in OD.
So....
easiest (easier than ripping the amp apart again) would be to use stand-alone preamps (say #102, #124 and even earlier) and see what fits best with the Power amp? Maybe I am all off, but this specific amp with this set of transformers really is though to get right.
I hope this makes at least a bit sense.
Thanks again for all the input!
Ah and by the way:
I would love to hear a demo of a #183 clone or the Quinn #183 preamp with a Strat/Tele on the neck pickup. One usually hears humbuckers (bridge that is) and this is sounding quite nice over my amp btw (Tokai Love Rock, or Tele bridge).
Electron
