OD Reverb is done... maybe
jackson649
Post by jackson649 »
Hello, I was wondering if someone could help me with what parts are needed for the tweeking the clean channel. I mostly use a single coil strat, so I am look for a more blackface fender sound. Thanks
Bob-I
Re: OD Reverb is done... maybe
Post by Bob-I »
jackson649 wrote:Hello, I was wondering if someone could help me with what parts are needed for the tweeking the clean channel. I mostly use a single coil strat, so I am look for a more blackface fender sound. Thanks
Well, that's not really the sound of a Dumble. It's far fatter and hi-fi than a BF Fender. You might get more of a BF sound by simply tweaking the tone controls, less mids and bottom, more highs.
Tonegeek
Re: Great
Post by Tonegeek »
hipbluescat wrote: I have seen a guy in Thailand that does copies of Dumble amps chassis. Does anyone have his contact details?
Paul
This may be the guy in Thailand: http://vasinguitaramp.tripod.com/id2.html
I think I saw a post here from someone who used his chassis. do a search on Thailand.
w
Pitcher Amplification
http://pitcheramps.com
jackson649
delete
jackson649
[quote="Bob-I"][quote="jackson649"]Hello, I was wondering if someone could help me with what parts are needed for the tweeking the clean channel. I mostly use a single coil strat, so I am look for a more blackface fender sound. Thanks[/quote]
Well, that's not really the sound of a Dumble. It's far fatter and hi-fi than a BF Fender. You might get more of a BF sound by simply tweaking the tone controls, less mids and bottom, more highs.[/quote]
I think I should elaborate a little more. I have been reading some reviews of Two Rock Custom Reverb amps and many descirbe the clean channel having blackface tones but not as shrill, and 3d sounding and what not. I have never played any Dumble style amps before so I was wondering if anyone knows how to make a dumble clean sound more like a Two Rock.
Bob-I
Post by Bob-I »
jackson649 wrote:I think I should elaborate a little more. I have been reading some reviews of Two Rock Custom Reverb amps and many descirbe the clean channel having blackface tones but not as shrill, and 3d sounding and what not. I have never played any Dumble style amps before so I was wondering if anyone knows how to make a dumble clean sound more like a Two Rock.
That sounds more like it.
Can you record some clips? It's hard to tell you what to adjust without hearing it at all.
jackson649
recording
I'll try, don't really have any recording gear, but I'll figure something out.
Bob-I
Re: recording
Post by Bob-I »
jackson649 wrote:I'll try, don't really have any recording gear, but I'll figure something out.
Typical components you'd want to tweak in the clean side are the coupling caps, tone stack caps, cathode caps, series resistors, input grid stopper, voltage on the plates and the bright cap on the master volume.
hipbluescat
Post by hipbluescat »
Hello Tonegeek
Yes that is the web site. Thanks.
What is the difference between a steel chassis and aluminium chassis on the tone of the amp ?
Can anyone explain why FET input has been used in some amps and what they achieve.
Thanks for everyone help so far.
Regards
