Can I come out of my D'lite loop and into the HRM loop?
						6V6 HRM
Re: 6V6 HRM
Yes...Dlite send to HRM return..Let us know what gives..dcribbs1412 wrote:Tony
				dcribbs1412
Re: 6V6 HRM
After Norm's suggestion about the PI
I changed the PI resistors(110k,100k) and caps(.1 6PS)...no luck
then I changed the NFB resistor from 5.6k to 47k and plucked a chord
and no thumping. Was able to crank it pretty good and no motor-boating
(if that is the correct term for this anomaly)
other than the graininess(see below)
Not sure what exactly I did wrong....was it coincidental?
I do have a sizzle or grainy sound in the back of notes and chords both
clean and OD. Tried a few different speakers same thing.Tried a few tubes in V1 V2 and V3 no change...
Will be dropping some voltages ASAP as I have 320v now on V3..could this be causing the graininess?
Darin
and no thumping.
  Was able to crank it pretty good and no motor-boating(if that is the correct term for this anomaly)
Darin
				dcribbs1412
Re: 6V6 HRM
After a few more changes (dropped voltages to V3 to 305,310 V2 200,195 V1 190 ,185 loop 245,215)
I still have the graininess on both clean and OD channels
also when I set the imp to 4 ohm the thumping is still there(not as bad)
no thumping on 8 or 16 ohm
any ideas are appreciated
Darin
Darin
				dcribbs1412
Re: 6V6 HRM
Hi Tom
changed it to 47k
now the thumping is only when I switch to 4ohm on selector?
the graininess is still there...clean and OD
any ideas?
						changed it to 47k
any ideas?
