Bias Pot
gilgalad101
Re: Bias Pot
There's one over at turretboards.com
Re: Bias Pot
Antique Electronics has them.
http://www.tubesandmore.com/
Search for part # R-V10KL-BP-FND
I personally prefer dealing with Ken over at Watts Tube Audio though.
http://www.turretboards.com/
<i> "I've suffered for my music. Now it's your turn."</i>
Re: Bias Pot
I like using the PEC pots with the short, slotted shaft and the locking nut on the bushing.
You make your adjustments then screw the lock nut down snug and there is no way that it can be bumped or mistakenly turned.
I've seen some guys use regular pots and even put knobs on them.
Bad mistake, IMO. Somebody always feels the need to twist knobs.
Re: Bias Pot
To each his own. Depends who is using the amp.Structo wrote:I like using the PEC pots with the short, slotted shaft and the locking nut on the bushing.
The PEC is a regular pot. It isn't really made to handle DC voltages.
- David Root
Re: Bias Pot
PEC spec sheet states "Operating voltage: 500 V, subject to power rating"
Doesn't say if AC or DC but I have been using them as bias and presence pots for several years with no problems whatsoever. Now if they were to have an amp or two across them that might be another matter, but a mA or two I think they are fine.
Re: Bias Pot
I'll bet that the PEC pot is rated for higher service than the CTS (or whatever) pot in your Fender - of ANY vintage.
Me: Just one more...
Re: Bias Pot
Man, you are a half empty glass type fellow aren't you.ChrisM wrote:To each his own. Depends who is using the amp.Structo wrote:I like using the PEC pots with the short, slotted shaft and the locking nut on the bushing.
Just how much "DC" voltage are we talking about here?
Re: Bias Pot
Thanks for the input guys.
Ken
Ken
Re: Bias Pot
Yes, always get told that.Structo wrote:Man, you are a half empty glass type fellow aren't you.ChrisM wrote:To each his own. Depends who is using the amp.Structo wrote:I like using the PEC pots with the short, slotted shaft and the locking nut on the bushing.
45mv?
I have a very negative outlook on things unfortunately.
Re: Bias Pot
I figure the glass is not half full, or half empty. It's simply at 50% capacity.
Re: Bias Pot
Amen!Deric wrote:I always figured it was just time to order another beer....
Andy
Re: Bias Pot
+1Deric wrote:I always figured it was just time to order another beer....
