I know there is the 417-8C, 75W rated, and earlier -8A and -8B versions with different frame design. All Alnico magnets. All 8 ohm except some very early ones at 16 ohms.
Then there is the 417-8H, 100W rated, aluminum dust cap, Series 1, all Alnico magnets, and later Series 2, ceramic magnets.
And now there is Great Plains Audio which is three ex-employees of Altec who bought the tooling from Altec when they went out of the pro audio biz. They are selling the 417-8H with aluminum or paper dust cap for (wait for it!!) $340.00! According to an e-mail I got on inquiring about it they said that "The 417 has a paper cone, but the dust cap is aluminum. Most guitarists prefer it, but we could make them for you with paper dust caps, if you prefer".
According to a post Funk made here back in '07, HAD preferred the Ceramic 417-8H, which is the Series 2 I believe. These have only aluminum dust caps as I understand it, unless you had it changed to paper.
Somewhere else I have seen that the 75W version has better tone than the 100W because it use a different coil former material (paper vs. fiberglass??). Paper being less inclined to ice-pick when pushed hard.
I'm looking for experienced opinion with these, further historical HAD references/info, and generally anything useful tonewise.
I certainly get sticker shock at $340, but perhaps the new ones are worth it? Used ones I have seen reconed at about $200 and FleaBay is always a risky proposition in my book. (Good place to sell but not so good to buy stuff like this).
						Altec 12" 417 series Speakers
- David Root
Re: Altec 12" 417 series Speakers
And I thought the EVM's were expensive......
Hi David, FWIW:
My ODS amp came stock with the Altec 417 8H /Series 2 in 1979.
The way I remember it it sounded pretty good, especially for cleans,
the OD sounds had a metallic edge to it, but it worked ok with the fairly low gain of the 70s amps.
Later I had the aluminum dust cap changed to one made of paper,
EV replacement part I believe.After that change the metallic edge was
gone, but ,unfortunately, all the high end was gone as well,
I remember turning the treble up full to compensate for this.
So I wouldn´t recommend changing the aluminum dust cap on this speaker.
Overall, I think the Altecs are a little to hi-fi for guitar amps,
and for most tastes EVs, Celestions etc are a better choice.
You have to keep in mind that ,at the time, there were only a handful of speakers with power handling capacity above 50 watts
Have fun Marcos
Have fun Marcos
re
David...you've got the Altec story correct, as far as you went.  As for the sticker shock, colbalt (a component in alnico magnets) has shot up in price just this past week.  A speaker I got new last week for $189 went to $269 overnight...literally.  So $340 for a speaker that uses a large alnico magnet is not as rediculous as it might initially seem, given the current price of cobalt.
Mk Boogies and ODS Dumbles may prefer a more "hi-fi" speaker than the usual guitar amp. Without a speaker that is sensitive enough to pick up on the detail in a heavily compressed signal, the tone is going to turn to mud. (YMMV) I have a Boogie MkII I run with a JBL D120F or an Altec 417-8C...depending on what I'm going for. I personally don't like the H models with kapton voice-coil formers, but I think that's more a matter of taste. That said, the speakers are more similar than they are different.
- David Root
Thank you very much Gents. I am currently looking at a pair of original cone 8H Mk 2s as a possibility.
I need one for a #13 50W build in a Princeton Reverb chassis, but that could use the -8C at 75W if I could find one.
Then I would have two -8Hs for an open back 2x12 like Avatar or Funk's source, for my just finished approx. # 124 x 100W and the Music Man HRM that is also on my build list. After those three basic lessons I will start to improvise.
