copper clad board
copper clad board
just a quick question for you guy's who has ecthed your own precision power supply boards, what oz. copper board is appropiate.
mouser has 1 oz. and digikey has 2 oz. or do I need somthing bigger. where does everyone buy their board?
thanks
neil
thanks
neil
						Re: copper clad board
The copper weight is about the currents you need to push.  For the B+, 1oz is plenty - just go wide.
There is also the etching time-vs-width thing to consider. Thicker copper takes longer. The longer you leave the board in the etchant, the more the edges of the traces you want to keep get eaten away. Again - go wide.
Hope this helps!
Hope this helps!
thanks don
i'll make sure and make em' wide as possible
You should check out McMaster-Carr as well, see how their price compares.
									"I never practice my guitar. From time to time I just open the case and throw in a piece of raw meat." --Wes Montgomery
I did check there the price is good but I only see it in 24-36 in. pieces and that more than I need right now.
If the 1 oz. copper was sufficent I'll just get it from mouser since I will be ordering from them ,and save a few dollars in shipping.
thanks
thanks
mouser # 590-521
I wonder what the dark green board is that I see others building the precision power supplies on is called?
That's a professional made PCB. Has been silk screened and solder masked. Not feasible for DIY.Structo wrote:I wonder what the dark green board is that I see others building the precision power supplies on is called?
Really?
I thought that Gil Ayan and a few others had made these boards.
Pretty sure Funkalicousgroove had some PCB company make those.Not DIY
