to use the full OT secondary or not...
Posted: Sun Apr 03, 2022 10:27 pm
So whenever I rape my own amp for a build or a friend donates their old broken combo to me, I always inject a fairly small ac voltage into each secondary tap, measure and record the primary voltage, then calculate the winding ratio, then the impedance ratio and divide that into various primary impedance's to determine what the tap impedance's would be for various power tube configurations.
But, I haven't the slightest idea if there is any difference in sound/performance/feel should there be an 8 ohm speaker on the 8 ohm tap or, a 16 ohm speaker on a 16 ohm tap of the same model and age speaker. I have occasionally heard people claim that it is optimum to use the whole OT secondary coil if at all possible.
I would be really curious to hear from those that have actually experimented with this to the point that they were thoroughly convinced that they either experienced a difference or not. I suppose the reason I ask is that when the time arrives to purchase a speaker for a project and I have the choice of matching the speaker to a particular tap, that a decision could lean on a collective opinion that it makes a difference or that it doesn't. If it was looking like the mass opinion was that it made no difference then I'd probably get an 8 ohm speaker just because it seems to be the most nominal impedance in my head. Ha. But, if many experienced players or amp guys swore up and down that there was some sonic benefit to getting a 16 ohm so to use up the whole darn OT secondary coil, well, thats no skin off my teeth either. I personally really don't care what speaker impedance I get if I have the tap to match it and its looking like there is no difference in the "coil real-estate" that is used, and it isn't more expensive for nothing.
Thanks all,
Best,
Phil D.
Thanks all,
Best,
Phil D.
