OK to Leave Cut Vinyl Edges Exposed?
Posted: Sun Mar 06, 2016 7:07 pm
I made a cabinet for a head. The covering is vinyl with a fabric backing. It was not long enough to go all the way around the box, so there is an extra strip in the bottom, overlapping the edges of the bigger strip that covers most of the amp.
I was afraid to leave cut edges exposed, figuring they might fray or something, and I also thought it would be hard to get them straight. The edges of the middle strip are folded over.
The problem is that now the covering is thick where the folded parts are, and the edge of the chassis rests on them. The chassis is raised slightly in front because of this, and that pushes the knobs up just enough to create interference with the front panel when I want to turn them.
Can I get away with just cutting the vinyl and leaving a cut edge exposed, or do the amp makers have special powers that enable them to do stuff I can't do?
