best finger joint jig
stretch2011
Post by stretch2011 »
Anybody have a referred finger joint jig? I have a router and table saw so I can go either way.
Re: best finger joint jig
I prefer a template type jig.
A step type jig can accumulate error over a long joint.
I use the Leigh 24", got it used for about 250.
You can of course do them with a backsaw too.
stretch2011
I'm decent enough with handsaws. But for real precision I'm sloppy. That's why I only mentioned table or router. Thanks I'll check it out.
The sled type for a table saw with the index pin seems to be what a lot of guys use.
Uses a dado blade.
Or you could always do it by hand. :D
Not in the league of a Leigh...this sort of template is screwed onto a block of wood and then the workpiece is clamped to it. You can easily shift and realign it properly for more cuts. Doesn't cost like a Leigh, either. I think it depends if for hobby or professional production.
http://www.ebay.com/itm/ALUMINUM-1-2-IN ... 416fbb2491
stretch2011
Yea I seen that last one. I also seen a router table one that slips the first cut over a block then the next and so on so they are spaced the same. Iys on eBay for $90. Looks pretty good I watched a guy make some super tight fingers
If this is what you're talking about, it's $60 direct from Rockler. This isn't the first time I've seen eBait higher than retail. Always verify that.
http://www.rockler.com/rockler-router-t ... -joint-jig
This is one clever table jig.
stretch2011
Yea that's the one. That doesn't surprise me.
stretch2011
Just read the bad reviews. Won't be buying that one.
ER
Post by ER »
I use a homemade sled pin jig like structo describes. I cut both pieces of a joint at the same time so they always fit. Cut a pair of test pieces first to get the right dado spacers in place and the depth set and then you're off to the races...http://www.finewoodworking.com/workshop ... oints.aspx
stretch2011
Looks good and easily adaptable to a router table. 2 questions. What's the front panel for other than a shield, it looks like it's just screwed in place up front. 2nd is how do you cut 2 pieces at the same time? I have a pretty good idea just want to make sure
