Page 1 of 1
Birdseye 'low rider' head shell
Posted: Mon Apr 07, 2014 2:13 am
by Geeze
I have a new Frenzel head that needs a shell to protect it. Whilst at a guitar builders guild meeting I found this maple hiding in the wood stack [we meet at a Rockers - devious buggers!]. Cut to size and sanded I cut the finger joints today. Did a really good job on the joints - not so good on the measuring.
The sides are 1.5" shorter than they should be giving me about .125" clearance on the 6L6's. Not enough for heat dissipation even with a semi vented front panel. Luckily I have more maple.
I will edge it with walnut. and oil as usual. I thought briefly of cutting vents in the top but I can't bring myself to do it.
Oh well.
Re: Birdseye 'low rider' head shell
Posted: Mon Apr 07, 2014 3:37 am
by Cantplay
We've all done it.
If you want to take the time on box joint you can leave the ends uncut and miter them on both sides. Its extra work, but it gives a really sweet look.
Posted: Mon Apr 07, 2014 2:47 pm
by Phil_S
Sorry to hear of your mis-measure on that beautiful wood. It happens. You'll find another use or maybe figure how to use it. At first I was thinking you can cut a couple of holes and use these:
http://www.homedepot.com/p/Speedi-Produ ... 907297-_-N but on reflection, I think, no matter what color you paint them, it will be butt ugly and it still doesn't address the low clearance problem very well. You'll still have to pull the chassis to change the tubes.
Posted: Fri Apr 11, 2014 3:01 am
by Geeze
After much contemplation about the folly of tempting the finger joint gods to smite a sinner like me I decided for a decorative feature rather than cutting more maple. Being an opportunistic cockroach [some might call it lazy] I took advantage of a spare 1" wide walnut and some 1/4" red oak laying about. Sometimes those 'I might use this someday' purchases of wood I really didn't need come in handy. Back on track! On to the drum sander for more thickness reduction.
Posted: Fri Apr 11, 2014 11:34 am
by Cantplay
Good save.
If you have enough, lay up more stock the same way, oak/walnut/oak as a strip, round it and slice into knobs.
Posted: Fri Apr 11, 2014 9:46 pm
by Phil_S
Cantplay wrote:Good save.
Really. You can say that again! I wish I had the tools to do that...and the imagination.
Posted: Fri Apr 11, 2014 11:09 pm
by NickC
That's definitely a "thinking outside the box" solution to saving the box. Well done!
Posted: Sat Apr 12, 2014 12:38 am
by LeftyStrat
That's similar to what you can do with the Incra jig:
https://www.canadianwoodworking.com/sit ... k=TZ9l1G_e
Posted: Sun Apr 13, 2014 12:28 am
by Geeze
Sides assembled and trim glued on. Probably 1/2" rout the outside edges. On to epoxy gaps and cut front panel.
I've never mounted a head in a shell. Any recommendations?
Lefty,
I have always admired those style of joints - waaaay too lazy to try it.
Posted: Sun Apr 13, 2014 1:37 am
by LeftyStrat
Oh, I see now where you were extending things, not like my picture at all. That looks fantastic BTW. I love walnut.
Posted: Sun Apr 13, 2014 1:40 am
by LeftyStrat
Geeze wrote:
Lefty,
It's definitely time consuming. The Incra jig can do some precision work, but it's not fast.
Posted: Sun Apr 13, 2014 10:48 pm
by Geeze
Finish sanded to 220 on to slurry sanding then oil, oil, oil.
Posted: Mon Apr 14, 2014 10:57 pm
by 10thTx
Very beautiful! Thanks for sharing.
With respect, 10thtx
