Page 1 of 1
dumb Celestion Gold question
Posted: Mon Mar 17, 2014 7:23 pm
by jaysg
I don't have one to look at....where does it tell you whether it's the 8 ohm or 15 ohm version? It's clearly not on the main label.
Re: dumb Celestion Gold question
Posted: Mon Mar 17, 2014 10:45 pm
by echuta13
Hrmm... I have some at home, but till I get there.. Maybe like this one? [img:2981:2236]http://cdn1.gbase.com/usercontent/gear/ ... zyc_so.jpg[/img]
Posted: Mon Mar 17, 2014 11:03 pm
by jaysg
oooo....thanks!
I would guess that the original blues were only 15 ohm back in the early 60's, so it's not on the vintage style label for the Gold.
Posted: Tue Mar 18, 2014 2:11 pm
by Phil_S
Your meter will read about 75% of the rating. That is, ~12 Ohms for a 16 Ohm speaker, ~6 Ohms or so for an 8 Ohm, etc. It isn't perfect, but you'll know when you see the reading. If you don't feel it is too disrespectful, use a Sharpie to write the result on the speaker. I know that's what I'd do. BTW, Sharpie usually wipes off with a rag and alcohol.
