Hey there,
I'm wondering if anyone has any advice on how to cut beading channels on cabs?
Cheers.
						Beading channels
Re: Beading channels
I'm not sure what you want.
Do you mean banding?
If you need to cut a groove or channel its dpne with a router, or if you are old school, with a hand plane.
In either case you clamp a piece of wood as a guide for the edge of the tool.
Sweet,
That makes sense. I'm pretty new to cab/amp finishing so trying to get a good handle on the different techniques.
For interest's sake I have attached a photo of my first refurb.
If anyone has some good how-to sites it would be appreciated.
Thanks!
Thanks!
				amplifiednation
It works well to cut a 1/8" deep groove with a full kerf table saw blade.   Or if the cabinet is large, use a router with an 1/8" straight bit, 1/8" deep
I wouldn't recommend doing it if you are doing a recover but it is entirely possible, I've done it many times. Any stick from glue residue is not safe for a table saw,
so make sure surface is clean and smooth!
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
