Speaker distortion
Vox and Hiwatt Discussion
plookit
Speaker distortion
Post by plookit »
I made a Vox AC15 clone amp some years ago and finally got it into a cabinet last week and I have a nasty speaker distortion/rattle vibration. Would anyone recognise what the issue might be from this short clip. I’ve tried three good speakers and they all do the same so it must be the amp. The sound files are too big for here so have put them in a folder in Dropbox called Distortion problem. Thanks
https://www.dropbox.com/sh/sw1w09svquva ... xzEra?dl=0
Re: Speaker distortion
Post by Stevem »
Remove one output tube at a time and play.
Does the sound quality stay the same, or do you loose output totally when one of the two tubes are removed?
Post by Stevem »
Mr moderator, should this string get moved to the Vox section seeing as his speaker is not the issue?
plookit
Post by plookit »
Stevem wrote: Wed Jul 19, 2023 10:55 am Remove one output tube at a time and play.
Thank you for your reply. I have located half of the problem, unused (not anchored) captive nuts for the rattle and fizz and I think the squeal is to do with the variable voltage regulator I put in. If I don’t max out the volume it does not do it.
Post by Stevem »
That's a small chassis if it's like a original one to try and implement a power scaling circuit if that's what your referring to?
You may need to work up a copper shield.
pompeiisneaks
Site Admin
Post by pompeiisneaks »
Stevem wrote: Wed Jul 19, 2023 10:57 am Mr moderator, should this string get moved to the Vox section seeing as his speaker is not the issue?
agreed and moved.
~Phil
tUber Nerd!
plookit
Post by plookit »
Stevem wrote: Wed Jul 19, 2023 3:41 pm That's a small chassis if it's like a original one to try and implement a power scaling circuit if that's what your referring to?
Can you tell me a bit more about this please. I added a variable voltage regulator which lowers the b+. It is effective for lower volume distortion but I suspect it’s the cause of the squealing when I have the volume on full (VVR not being used). I have used an authentic reproduction of the AC15 chassis. I wonder if I should take that out as I don’t hear the ‘chime’ either.
B Ingram
Post by B Ingram »
Stevem wrote: Wed Jul 19, 2023 3:41 pm That's a small chassis ...
plookit wrote: Thu Jul 20, 2023 6:28 am Can you tell me a bit more about this please. ...
You have Output Transformer/Speaker wiring right next to the Input jacks. That's a recipe for nastiness.
Vox kept that junction block further from the Input jacks. You could also add a metal plate between it and the Input jacks, that is bolted to the chassis (which then acts as a grounded shield between Speaker wires & put jack wires).
