New dual EF86 project
- randalp3000
Pulled out my old Stangray a couple weeks ago and man did it sound killer. The cleans on this amp are stellar and thought an added brilliant channel to AB between would be awesome.
So this is the next project, the Ranray. Going with an Allen chassis, Hammond 300-0-300 230mA power trans, Hammond Vintage AC30 OP, and Hammond 10H 125mA choke. Also trying filtering on the preamp board with different grounding scheme(I swear I'm not copying you Mark). Also doing a PPIMV for the first time so it's easier to adjust volume for both channels.
This is day 1, chassis prep, layout, and boards, 2 hours. Didn't know the chassis had to be drilled for transformers and such and I'm trying to keep track of my time.
I left some values out of the schematic out of respect for the doc and some things I changed. Mostly it AC30 stuff.
Re: New dual EF86 project
Sounds cool, dude. I bought an old Mazda made Bugle Boy EF86 on Fleabay a while back and yesterday got the urge to wire it into V1 in a Watkins Dominator style amp I didn't really like all that much anymore and today when I pulled it out, it cracked, but I didn't know it when I pulled it and I set up the amp to play and nothing. I then observed it and saw a hairline crack through the middle of the pins and a short way up the side.
Luckily, it was just a used one and not expensive at all. Still, quite the bummer today. I'd only played that thing once. Poor little Bugle Boy!
Randal,
Sounds like a great project.
Oh yeah, then explain the blue boards buddyAlso trying filtering on the preamp board with different grounding scheme(I swear I'm not copying you Mark).
- Reeltarded
Looks like Fowler Blue to me!
So I guess we can call Mark 'Heisenberg' from now on??
"Stay out of my territory".
I got the popcorn out and taking notes.
- randalp3000
Thanks and sorry for the blue boards, didn't know you had a tradeMark on them
more work done, added an IEC socket and layout in the background.
- Reeltarded
Over the next few seasons less people build amps and Mark becomes a very dark character. I like it.
Mark's blue stuff is Classic Coke and the rest of us use some generic off brand crap.
Don't blow us up, Mark!!!
- randalp3000
2 more hours down, lots of progress. I hate wiring filaments but discovered half way through that tinning the leads makes it much easier.
I've got power, 309-0-309 with no load.
I went to the beer fridge to grab a coke and look what you've done Randal,
Looks good.
Looks good.
- randalp3000
thanks Mark,
I probably wont be able to do any more work til Sunday
gig tomorrow night and I should spend some time with the little lady.
- randalp3000
More work done last night, gettin close.
- Reeltarded
Nice work man! Looks very good.
Nice build, but kind of redundant eh? You could easily switch-in both kinds of eq/volume control for each using a single EF86 and dropping the mixing 220ks.
Maybe I'm just a bit more frugal w/ my EF86s'...
