Hello Mark,Mark wrote: ↑Sun Oct 04, 2020 1:44 am I tried a different set of output valves and much the same.
I thought the bright channel sounds very shrill through my 18 watt Marshall cab (which in fact was made with the same dimensions as an AC-30 cab, the cab is loaded with a Celestion Blue and a Celestion H30. I have seen this combination in one of Brian May’s AC-30’s).
I've wondered about this combination of speakers. Are you using the Celestion H30 Anniversary edition?
You have probably seen this from Greg Fryer's site:
https://fryerguitars.files.wordpress.co ... an-may.png
I'm sorry for not replying about the zener bias condition. I have been moving the past couple of days and getting my place sorted. That is peculiar. I used the triode grid curve method by Kuehnel, shown here in his analysis of the AC30, to estimate the tube currents:Mark wrote: ↑Sun Oct 04, 2020 8:40 am I have removed the three zeners and put a 75 ohm resistor in its place. The rail dropped to 315VDC, I have 307VDC on the EL-84 plates and 11.3VDC on the cathode. The valve 29mA of current going through it per a 1 ohm resistor mounted between the plate and the output transformer primary. I estimate that the valve is dissipating 9 watts which is a good spot for a class A/B amp. I’m using a 100uF bypass cap at the moment as it is what I had on hand. I can’t say I’ve noticed a massive tonal difference between the zeners and the resistor and cap.
My experience with my Trainwreck Rocket was that I’d need much larger cathode resistor to stem the current flow. So this amp has me a little perplexed.
What are your thoughts on current flow through the output stage of an AC-30?
https://www.ampbooks.com/mobile/classic ... /vox-ac30/
He says it provides a reasonable approximation where the screens and plates are very close together in voltage. I was going to ask if you were planning to replace the zeners with a resistor, and you have, to a good outcome. Your new rail voltages seem spot on and the PT is sagging nicely. What is your Mains voltage at these settings? According to my calculator, with your new conditions of 11.3VDC cathode, 307V plates, and bias at 75 ohms, it is estimating 151mA for a quad (37.7mA single tube), 11.1W (per tube) and 93% of max dissipation, so your results are fairly close. Can you put in a 1R across the rectifier to B+1 to measure total current drawn by the amp to see how this compares to what you are getting with a single tube measurement? Thanks for doing all this work. It will help me greatly with my own AC30/4 build. I have estimated the power amp conditions. I will be using a Mercury Haddon clone PT, choke, and OT and took secondary resistance and inductance measurements on both to see how the predicted values for B+ will compare to the as-built. The original PTs were wound for 115-160-225-245V primaries. The Mercury runs 100-117-220-230-240V with a 285-0-285V (unloaded) secondary. My mains run hotter at 123VAC, so using the 117VAC primary, I am planning to add some additional series resistance to each leg of the secondary and a small value, post rectifier, if needed to get the rail where I want it.
