I'm in the process of "restoring" a 2nd Thomas Vox Berkeley III head using RG Keen's marvelous circuit board and information.
Had a dead reverb tank so the wiring to the tank and transformer were disconnected. (T3)
While I have the schematic and such, I don't have a real picture/diagram of which wires go where on the transformer.
I know the Red voltage goes to one winding which then goes to the driver transistor.   The cable to the In of the tank connects to the other winding
Problem is - without any connections to the transformer I'm not sure which goes where.  I temporarily connected the wires and got an unreal howling out of the system when the IN was connected.
I could have a bad transformer anyway - not sure if any replacement exists.  But that's another issue.
If anyone could send me a photo or a diagram of the reverb transformer found in the Thomas Vox solid-state models (Cambridge reverb and Berkeley 2 & 3) it would be a great help.
Otherwise the unit works great
Mike
						VOX Reverb Transformer Information
Re: VOX Reverb Transformer Information
That howling is positive feedback.
Reverse the transformer wires and you should be golden!
