Im no where near done but looking foward to building a TrainWreck Express and would love a link to the MOST updated layout/schematic
AC15 build started
AC15 build started
So I started building Sluckeys version of the AC15. I ordered the board parts, cut/drilled/pressed turrets. I wired mains on its board minus flying leads and will start to populate the other board today. I shorted my turret count so Im waiting for those plus .1uf caps I forgot. Here are some pics that I posted on my other forum at BYOC.[IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/008C8087-AF96-4D7F-BF30-310AF9FD8799_zpspkdw4gei.jpg[/img][IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/FFD58284-6286-46A9-891B-C172BE539A00_zpsnnymz4gz.jpg[/img][IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/4D735D93-5E3A-4878-8AC3-F792E6DEF77E_zps9oxuh9qz.jpg[/img][IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/C9298B6B-9CB3-43A5-9FFC-9DEA09D8E509_zps1d12inv0.jpg[/img][IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/513154EE-27E2-426E-8428-AF6CC8CCF6EF_zpsm6mrzn9y.jpg[/img][IMG:640:480]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/55840D3D-745E-4084-8EC3-0893152F07E2_zpsudaktity.jpg[/img]For those of you that have and will offer help, Thank You.
Re: AC15 build started
Holy crap there are a lot of turrets in one of these builds.
Aside from a main cap board the AC15 has TWO full boards
Sluckey put this together and squeezed into one thankfully.
TNblueshawk
Keep at it Lionel. I plan to look back on this thread, and the one at BYOC, when I build it at some point.
I'm letting you vet out all the frustration first
[IMG:768:1024]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/382EDCD8-979C-46AB-AE53-4A7731684C75_zpsalosk3hr.jpg[/img] something to hold board and ground bus started
Looks really good man. That's gonna be a helluvan amp!
[IMG:768:1024]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/3817E6F5-AC2A-4981-9827-5A7C79CDEA5F_zpshtcf4zgr.jpg[/img] that's it for this weekend on my project. It's gonna be fun soldering this up
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/5F3F9779-934E-4DFE-9A71-30507DDD55D1_zps6niqcne8.jpg[/img][IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/EA11C4E1-FBFC-456D-9B8E-C09053E71D65_zpswq8agnux.jpg[/img] some work done, some parts need to be ordered for board still. This is gonna be a challange for me when It comes times to solder
This is fun to follow, very nice so far, please don't drop it. Curious why you mixed brown Xicons and 150s, just what you had, tight space, tone fine tuning?
I thought this was going into a Marshall chassis, I would have expected upright can caps, where does the doghouse board go in this, or is it for a fender BF style chassis?
The Xicons were used because of tight space, it was designed to go in a 17" chassis but a 20" was recommended for extra room. No dog house I think, I will have to mock up and see if I can get it inside. The usage of top mounted transformers will give me a ton more room inside. There is one Mallory on the bottom just left of the Xicon I want to change too, I don't like the way I had to bend the leads. I'm taking it slow, I must've traced components ten times everyday to make sure I haven't forgotten something. Next purchase is gonna be a biggy, chassis and head along with all other parts
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/181A75DD-744B-4AD1-806C-2C6DB758AD1B_zpsytwjffff.jpg[/img][IMG:768:1024]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/D9E77004-A595-4AF0-88E9-6267048EF834_zpsn4hzpflh.jpg[/img][IMG
768]http://i77.photobucket.com/albums/j72/legomaniac4040/Mobile%20Uploads/8399AA35-BEE9-4711-B61C-138465F4CCF3_zpsuggoyapc.jpg[/img] So I got the Board soldered up and after checking the underboard a few times I realized one was wrong, I fixed that tho. Im in limbo waiting for chassis and all the other parts with a couple on back order. No choice a cab yet.
Nice. Lots of components per real estate there! I'd expect to see a lot of jumper wires underneath, but this layout is cleverly thought out. Kudos to Sluckey or whomever designed the layout. Hopefully it won't oscillate when you crank the treble...
EL844??? Hummm.
EL844??? Hummm.
Mine is done. And it works great. Here's a link to my project...
http://home.comcast.net/~seluckey/amps/index.htm
TNblueshawk
Dang Steve, you made that process look easy. I've been following at Hoffman every step of the way.sluckey wrote:Mine is done. And it works great. Here's a link to my project...
