Would this be a place to start?
http://vancouver.en.craigslist.ca/msg/1253163049.html
Stew
Trannies for a TW
Re: Trannies for a TW
I have used from here:
http://www.toneslut.com/transformers/index.html
Others also use from here:
http://www.edcorusa.com/
Gary
Gary
In the 60's people took acid to make the world weird. Now the world is weird , and they take Prozac to make it normal.
Thanks Gary.
The Toneslut outfit has a good deal for shipping to Canada I didn't realise!
Stew
Stew
Toneslut trannies are pretty much the standard by which others are compared.I have used them in two Express amps and I used their PT in a Rocket. Excellent stuff.
Amen to Toneslut
Moose is a great resource
Check out this thread:
https://tubeamparchive.com/viewtopic.php?t=7938
Tim
Those trannies on craigs list would be good for building a Dumble SSS using Fender twin four tranny set but not for a Trainwreck. Use tonesluts Heyboer or get a set of Pacifics from Allynmey or set of Edcor from rjguitars.
- RJ Guitars
Thanks Mark,M Fowler wrote:Those trannies on craigs list would be good for building a Dumble SSS using Fender twin four tranny set but not for a Trainwreck. Use tonesluts Heyboer or get a set of Pacifics from Allynmey or set of Edcor from rjguitars.
I've got a good start on an Express build with Edcor trannies that will be the first use of these trannies in that amp (as far as I know). There are a hand full of Rocket builds out there using Edcor trannies with favorable results but the Express & Edcor combination is still an unknown. I'll post up the results and allow myself to be the guinea pig for field testing them.
rj
http://www.rjguitars.net
