Help with TW PT Wiring (toneslut trannies)
Guitar Adjuster
Post by Guitar Adjuster »
I am trying to wire up my Toneslut PT but I am getting confused somewhat. The two large brown wires are the heaters and the large brown and white striped wire goes to ground. The two solid black wires go to the power switch. The yellow and green striped wires get cut and shrink wraped and the yellow and red stripe wire goes to ground. The two soild yellow wires go to the Diodes on the power board? Where do the 2 solid grey wire go? Thanks for the help.
Allen
mlp-mx6
Re: Help with TW PT Wiring (toneslut trannies)
Post by mlp-mx6 »
Grey wires are for a tube rectifier if you have one.
If you want the higher voltage on your power tubes, you would use the two yellow wires as you state. If you want a lower voltage, you would use the yellow/green wires instead.
Me: Just one more...
Guitar Adjuster
Perfect! Thanks.
